What are the pros and cons of the 1+3 versus the 4"?
Here is what I have found out.
I have the 1 inch BRP riser on my Spyder from day one and it was just not enough for me. I must be getting too old for true sport bike riding positions anymore. LOL!
The 3 inch kit plus that BRP kit puts the risers at the max limit you can go with stock cables, and yet makes a REAL change in the riding comfort.
Thing is if I had to do it over again, I would not have waisted my money on the BRP kit as there is no advantage in doing it this way. It only ended up costing way more money to do so.
The reason we make the 3 inch kit is the BRP risers are a real pain to install or remove. So for everybody who already has these in place why waist the labor to remove them just to install the 4 inch kit. This way there is not another waist of good money to remove the BRP kit, just use the 3 inch kit along with the 1 inch kit from BRP.
I had the BRP kit installed by the dealer before I took delivery. The labor and the 1 inch riser cost over $150 all said and done. Now add in the 3 inch kit and you'll have almost $350 invested to get a total of 4 inch rise if you have the dealer install your 1 inch kit.
The 4 inch kit is only $209 and puts the bars in the same final position, saving you some real money with the same end result. :clap:
However you can use the 3 inch kit on a bike that has no BRP risers as well for those of you that want a bit less rise as the 3 inch kit will work on these bikes as well.
If you hve any questions just give me a call and I'd be glad to try to help you out. :thumbup:
MM
