Question. Recently, I was out in the boonies riding my '23 F3T (with only 13000 miles) and went to exit the main road and discovered I had no brakes. Fortunately, I was able to slow it down by downshifting and rolled to a stop. I discovered that the 10mm bolt that holds the brake linkage had fallen out.
My question: what would cause that to happen? Is that normal? I am beginning to lose faith in Can Am. I had a warranty replacement of the alternator assembly recently as well. Should I periodically be tightening external bolts like that, given the vibration? I wonder if the repair shop that replaced the alternator might have not fastened it, but they insist they didn’t remove it, which makes sense. Any insight would be appreciated.
