WHAT TO DO NOW ????
rwbcats
Today as I came home turned into driveway check engine light appeared once again...pulled fault code up PO174 ECM system too lean , injection and fuel supply system, check injector and fuel supply system... so if the shut it off and pull out the key and wait doesn't reset the system then what... I hope not a trip to the dealer
That won't reset an ECU, you should unhook the battery for a few minutes.
while disconnecting the battery will certainly do it. normally the bike will reset if you remove key, move away from the bike 5 ft or so to break connection between chips, wait three minutes and the restart... That has worked for me at least twice a year for over 4 years, to remove extraneous limp modes that never returned
Check the two vacum line to the MAP sensor
Do a search for vacuum lines. There is a known failure with the two vacuum lines that feed the MAP sensor. :shocked:
If they leak you will have the symptoms you are reporting.
Good luck!
- Mike
