What kind of brake fluid... I got the Brake Warning in 100deg heat
Sopher
Coming home from a 100 mile round trip, I got the Brake warning message.
I suspect brake fluid, but i cant tell.
I also read that even a half once will correct it.
What type/klind of brake fluid? BRP special or any auto store brake fluid?
Please be specific.
Dot 4, not sure if there really is a motorcycle brake fluid as compared to motorcycle oil, but I did use a motorcycle brand.
Please be specific.
DOT 4, and carefully clean the top of the reservoir so no dirt gets in, Also make sure you don't spill any, brake fluid will eat paint away.
:agree:DOT 4 - can be picked-up at motorcycle dealerships, some gas stations and even walmart. Check and wipe the caps and reservoir before you take the caps off.
Cheers,
Dean
:agree: and after opening and using the fluid, do not store more than 30 days, and only then in controlled enviorement, due to contanination.
