What is the Latitude of Ryker Vertical Headlight Range Adjustment?
gbyoung2
Shortly after I picked up my ’22 Sport I changed out the pathetic OEM headlight bulbs with some LED replacements. An improvement in brightness was obvious, but some slight tweaking was necessary for L<->R adjustment, but those were easily brought into into proper positioning as the adjustments were easily accessible. Adjustment changes were very obvious when the adjustment screws were turned. Unfortunately, the vertical beam positions were still too low, just like the originals. Since access to those adjustments were difficult to reach, I had to wait until the time came to pull the glove box so I could get to them.
That finally happened a day or so ago, but tweaking the vertical adjustment screws of the lamps showed no vertical up/down movement of either the left or right beams what-so-ever. I was expecting the same obvious response as the horizontal adjustments, but that wasn’t the case.
What am I missing?
