What is the difference between ssv speakers and kicker speakers?
kongdoly
I'm trying to mount speakers on my spyder f3s.
There are 2 types of speakers, what is the difference?
SSV Works 6.5
or
Kicker 6.5 (+$ 100.00)
I mostly like strong bass music.
SSV Works 6.5
or
Speakers from different manufacturers are likely to have different Tonal qualities, meaning they won't sound the same .... but they are both 6.5 in. so mounting them would be similar. .... having good BASS from a speaker smaller than say 10 in. just isn't going to happen.... (the size of the CONE matters) ..... good luck .... Mike :thumbup:
I need to try it to put a 10 inch speaker. thank you
IMHO - trying to achieve optimal sound ( clarity, volume etc. ) on any Mtc. is futile..... unless you only plan to use it in a parking lot situation. I love high quality sound, I have a 14 RT and got as close as reasonably achievable by changing to quality speakers ( using OEM radio onlt - no extra AMP ) like 2 OHM JBL's ... I also swapped out the 4 in. rear speakers for 5.25 " JBL's...... good luck .... Mike :thumbup:
