What are the frunk & trunk weight limits?
2to3
Just bought 2022 F3L :ohyea: What is a reasonable weight limit for the frunk & trunk? Asking 'cuz I would like to go bowling & take my (bowling) balls in the spyder. Size wise they will fit, but not sure about the weight. We're talking 3 - 14lb balls. Of course I'll make sure they don't roll around. Any thoughts?
put each in a different compartment ...... PS The Spyders have weight stickers for every compartment in EVERY compartment ..... Mike :thumbup:
You should be able to fit 2 bowling balls up front and 1 in top case without issues. The shoes and crying towel can keep the balls from shifting. The RT frunk is good for 35 lbs. I don't know the top case RECOMMENDED max but a 16 lb ball shouldn't be a problem. Bags will be a tough fit.
You should be able to fit 2 up front and 1 in top case without issues. The shoes and crying towel can keep the balls from shifting. The RT frunt is good for 35 lbs. I don't know top case RECOMMENDED max but a 16 lb ball shouldn't be a problem.
Thanks for the replies. Didn't know about the weight stickers :opps: I figure a roller bag can be tied down to the passenger seat. If not, I'll just fold up the soft carry bag & use it to keep stuff from moving around.
If you put too much weight on the passenger seat the nanny will think you're 2-up and be more sensitive to your riding 'style'. Maybe spread the roll-up across the seat?
Or a platform spanning the seat pad...
Sorry, I wasn't too clear....if I tie down the roller bag, it will be empty....bowling balls in frunk & trunk! Really not sure I could lift a loaded bag onto the seat.
