LesGrossman
I'm adding side mirrors with integrated turn signals to my Spyder. I need to tap the wire harnesses that supplies voltage to the front fender turn signals.
I can't find any links here that are working, that show the wiring diagram for the front fenders.
The fender harnesses (for the lights) have (3) wires.
Ground (black). And I'll assume one is the voltage for Daytime Running LEDs, and the other is for the turn-signal flash.
Looking to see if anyone can tell me what the wire colors are for which voltage source (the turn-signal or DRL).
(wanted to avoid removing the fender to pull the connector off to take voltage readings)
Thanks!
Thanks!
