Warranty info
tntnj
I just bought a 2017 F3 Limited. My extended warranty runs out 10-2-2020. Can I still buy the BRP extension for two more years (total 5 years )?
Hi,
Check with the dealer you purchased from. As long as the factory warranty hasn’t expired, you should be able to by 2 additional years’ warranty.
Is your extended warranty running out, or your OEM (2) year new vehicle factory warranty ? If you're still on your OEM factory new warranty, you can buy the BEST up until expiration of your factory two year warranty. I don't believe you can extend a BEST extended warranty. Maybe thru a 3rd party though ....
You can buy up to 3 years of extended warranty to give you a total of 5. The extended warranty just needs to be purchased before the original one ends.
I was told by one dealer that it was still under warranty ( forgot to ask when it expires) , I called another place to confirm when it expires and he said that it expires 10-2-20 and there was a 50 dollar deductible and it was under the extended warranty . I am thinking 10 -2017 was when it was first bought so this only 2 years on a warranty with an extenision of one year ? Will the dealer know when the original warranty when it to effect and the extended came into effect ? Can I still extend the BRP warranty?
Yes, the dealer can find that out for you. If you had one year extended you can purchase an additional two years coverage. You have to do that before the current coverage expires.
