crochford
Problem I was having was poor reception because didn't have a good place to mount it facing straight up. So here was my solution, took on of those 50cent Hurricane straps you use when building a deck, cut it down and bent it to fit the little cut in on the front of dash under the windshield. Drilled a hole on the cut down strap so I use the screw already there to mount the plate I made. I had to replace the bolt with a longer one and I also painted the strap black. Since the strap is metal and the antenna is a magnet it attaches perfect. Was a little worried that the windshield might hit it when moving it up and down, however no issue. Took it for a test ride on back roads that I always lose reception and it made a hugh differance.
