Voltmeter\USB\Lighter outlet
Tyris
Is there such a beast that would be able to go on a dash mount? I've seen two out of three, but not all three on the vendors here, JT come close.
I have JT's dash mount with 12 VDC (cigarette outlet) and 5 VDC (USB). I haven't seen a voltmeter that would mount to the dash mount. But what you could do is disconnect your fuel gauge and temperature gauge and replace them with a voltmeter and maybe a clock. Once you disconnect your OEM gauges they automatically show up on the center display.
Hmm, that's interesting, wonder if the digital is more accurate that the guages, there's not a setting to turn this on is there?
No, there is no setting to turn them on. You must disconnect the analog gas & temp gauges. The digital is definitely more accurate. You can remove the gauges & put 2" (52mm) blanks in the holes, or just leave them in place once you disconnect them. Be aware that if you do leave them in place, the analog gas gauge will always read whatever your fuel level was when you unplugged it. I will try and find a picture of mine.
Found it. I got them at a local boat dealer.
http://www.spyderlovers.com/forums/showthread.php?95694-RT-GAUGES-GONE&highlight=analog+gauges
