For those that have installed the vista cruise I would like to pick your brains just a bit about your install and how well it works since I installed one as per ATADUDE's instructions and it is a pain more then it helps.
1. once the vista cruise is installed and not locked how freely does the throttle move (i.e. do you have to roll off the throttle or will it return by itself)
2. once the vista cruise is engaged and locked how well does it hold the throttle. For example does it disengage if you go over a bumpy or rough road ?
3. just exactly where is the best place for the thumb lever of the vista cruise to go. On ATADUDES it appears to be more at the front of the switch housing but in a picture of Lammonts it appears to be more under the throttle towards the bottom of the switch housing then in front of it.
4. When you removed the ridge on the throttle sleeve how smooth did you leave the throttle sleeve where the ridge was.
I ask these questions because for my vista cruise to actually work I have to have it so tight that the throttle becomes a workout to get it to move. When I back off the set screw on the vista cruise to a point where I am not having to break a sweat to operate the throttle, the vista cruise either disengages by itself or slowly allows the throttle to roll off thus defeating the purpose of the throttle lock.
I am wondering if the "smoothness" of the throttle sleeve has anything to do with my problems and if rotating the vista cruise so that the thumb lever is more towards the bottom would eleviate the disengaing problem.
Opinions and suggestions are appreciated.
