Verdict is in... Sway Bar ROCKS!!
Raptor
If you missed my first post, here it is, just for review purposes!
I installed my Sway Bar this afternoon. All in all it was not a bad job at all; I found it to be a good way to get to know my Spyder alot better. The directions that came with the bar were very well written. There were only a few variations.
One was that they didn't mention the Skid Plate. No biggie though; 6 screws and off it came! Also, be very carfeul with the air temp sensor and don't lose the foam for the air sensor. And don't forget about the trunk latch! That takes care of the trunk.
One other thing was that the stop bushings (not the frame bushings; you get new ones with the new bar) that mount on the original bar will not fit with the stock hardware because the new bar is so much fatter, so I had to come up with an alternate mounting solution. But that too was no big deal as I had plenty of hardware laying about. :ohyea:
Of course while I had stuff off I cleaned all the suspension parts, adjusted my shocks, topped off my coolant etc. When I got everything cleaned up and sat on the bike, I could tell right away there was a difference; The bike didn't bounce like it usually does when I got on before. And of course, the big test; she fired right up and threw no codes! I'M TOTALLY STOKED NOW! :yes: It's time to take her out for a test. See ya when I get back!
__________________
OK, so I am back from my test ride. And all I can say is... HOLY COW!! That was money well spent for sure. Between the bar and the shock adjustment etc., the machine behaves completely different. I was even going to engineer some spring rubbers but right now I don't see the need. Here is what I experirnced thus far:
When I first took off, I followed a familiar route to see how it handled similar bumps. I still feel the bumps but the bike settles a bit quicker than before. Simple turns are now effortless with no rotation. Very good tracking and very true steer. So far so good.
I then got her on the freeway. rolling on throttle hard used to make the bike buck up really hard. Not so hard any more, much smoother getaway. Manuevering is very sweet and again the high speed track is amazing. I looked down and I was at 117! It did not feel that fast. This I can't explain other than the stability is even better than before.
Now on to the twisties. This brought the most surprising reults of all. The tendency to over-rotate is gone. The bike now attacks turns in such a way that I had to adjust my normal line a bit, inspiring much more confidence. I found that the stupid Nanny was kicking in a bit more. I found this odd until I looked down and realized that I was taking turns waaay faster than before. In fact there was one instance where I got too aggressive, hit a bump and got BOTH fronts off the ground! Wild man! That was a mistake on my part, but the bike held it's line and I powered out OK. I then proceeded on and took a smoother more relaxed line and got great results. I didn't have to work as hard to achieve good cornering. Very impressive!
I know this sounds dramatic but this is true. Remember, this was a Sway Bar replacement, a schock adjustment, I hit all the grease fittings and cleaned/inspected and firmed up every suspension component. I also went higher on tire pressures. I am now at 23L, 22.5R and 31Rear. Better spring rates from the side walls reduces tire flex.
This was a great excercise and produced a great result. I can't wait to get on her tomorrow! :ohyea:
:congrats: Glad to hear that it worked out so well, I've been thinking of doing the same. Where did you get your sway bar?
So this bar is for the RS right? The new bar I got from Evo for the RT was the exact same size as the stock bar. They sent new bushings and clamps (the clamps wouldn't fit, used the stock ones, also the stock bushings will work). The only difference in the Evo bar was the holes that you use to bolt them to the lower a-frame are closer to the centerline of the bar. This reduces the leverage ratio which increases the resistance. It does help for a solo rider, but doesn't do much when riding double. I don't suppose the RS bar would fit the RT? By the way if any of you are going to be installing the Evo bar on your RT if you loosen the bottom mounting bolts for the front trunk you can pry it back far enough to install the new one without removing the trunk. You may have to remove the bolts, CRS!
Dwight
HEY Y'ALL! -
OK, I know you were curious about the 1/2 pound Air pressure difference between tires. So here it is; Right hand cornering is great. However, She oversteers (or Pushes, if you will) on left handers. The half pound, believe it or not, makes the sidewall a bit softer thus lessening the spring rate and giving me more bite for the left handers. But at only 1/2 pound it does not affect forward track or steer. When you get to pressures this high on the fronts 1/2 pound makes a difference.
I'll have to check regaring the RS VS. the RT bar; I have not seen the RT setup yet. But I went straight to Evoluzione. I called them up and ordered it. They were very nice and I got my bar in 3 days! And when I compared the the new bar to the stock bar, the difference was very evident. The new bar is way beefier than the stock piece and has two settings. I went with the stiffer of course!!
hope that helps. Feel free to ask more questions if ya have 'em!
"One other thing was that the stop bushings (not the frame bushings; you get new ones with the new bar) that mount on the original bar will not fit with the stock hardware because the new bar is so much fatter, so I had to come up with an alternate mounting solution."
If you are replacing the sway bay on the 08-09 SM5 and SE5, then you will not re-use the old stop bushings, those get tossed with the old sway bar. The new sway bar has special angles on it, and that provides the stops now. Just an FYI for clarity.
evo's anti sway bar will be THE last mod that will come off my spyder, just before i part with my current spyder.:thumbup:
last time i took the sway bar off because i thought i was getting a RT, my inside wheel kept coming up on turns because i kept turning at the same speed i was turning with the sway bar.
I am more and more convinced everytime I read about this sway bar that I should get one. This thread is just another example. I was thinking of also getting the RT shocks.
Girl, you mus MUST MUST get one!! You will be very surprised at the difference. :D
The RT shocks aint a bad thing either. It's a reasonable alternative to shelling out 2K for Penske's or Elka's, though I wish so much I could take that plunge...
