U-fit Brake Rods
Test it before you buy it.
Anyone have the lengths of the different brake rods?
You can easily test your comfort length buy removing the 2-5mm allen screws that hold the floorboard/footrest and disconnect the break lever. Slide the floorboard/footrest forward/rearward to your comfort and that will tell you what rod you'll need. Easy.
35" inseam, I created a position 6. added 1.75" to longest rod and drilled new holes at the same distance.
