Two Up Riding
fenelonspyder
What is the recommended tire pressure and suspension setting for 2 up riding on a 2015 RT Limited. Total all up rider weight is 360 lbs. When I ride myself I find the middle suspension setting works best. Any help would be appreciated.
Under the seat by the Schrader valve there is a sticker that has the recommended pressure settings. There is also a picture of the sticker in your owners manual. If the middle setting works for you then go with that, it is pretty much all personal taste. Change the setting and see what your passenger thinks. As for the rear tire setting I would stick with 28 psi on a Kenda.
With the Limited; you don't need to monkey around with the Schrader valve under the seat. Just add a push or two to the rear suspension adjustment buttons, and you're good to go! :thumbup:
