Two questions
Commander
First question
I know it has been brought up in the past but where is the best place to put an EZ Pass, in the FRUNK or is there a pouch that can fit behind the windshield like some other bikes have.
Question two
I have a 2015 RTL and is there a way to enhance the shocks to give a better ride when we are riding two up?
Frunk or trunk works for iPass. Baja Ron has shock adjusters or Doc Humpreys that will help on the front shocks. Or the. Expensive way is replacing the shocks
Ride change on your RT Limited
First question
Question two
Just change your ride setting on your RT Limited by using your hard/soft ride button under your handlebars. You need your engine running, and I think you have to put it in 1st gear and then put your control button either for a harder ride or a softer ride. You have about 5 setting and you will see them change on your screen!
To add to....
If you have not installed a BajaRon sway bar and had a laser alignment it is a good place to start. Handling will improve dramatically and the added adjusters mentioned above will be icing on the ryde....:thumbup:
:agree:
Joe
For the E-ZPass I put both my wife's and mine on the frunk lid.
Hers, a 2014 RTL cognac color worked fine but mine, a 2013 RS silver color would only work about 1/2 the time. Perhaps the silver paint has more metal in it, attenuating the RF signal. I moved my E-ZPass up on my dash, inside a dash bag I already had on my Spyder. Works fine now and nobody can tell it's there inside the bag. Since this picture was taken I have painted the inside of the shorty windscreen black and put the larger windscreen over it and it's hard for passersby to see the bag now.
The bag is like this one I think, I don't remember where my bag came from and I'm not with my Spyder right now. You might be able to get one from one of our sponsors.
http://www.motoparthub.com/H41_153B...yd1gcqicUdLHSS3bn_nOTkutlMcsr5jHjQaAgsa8P8HAQ
Question #1: I have put my EZ-Pass in one of the pouches in the Frunk
(I had originally had it out on the dasg, but got nervous about the possibility of theft... :shocked:
Question #2: BajaRon's pre-load adjusters... :thumbup:
