Question 1: My bike has always had a noise that I'm pretty sure is pad rub, but only after the brakes are hot. This occurs only when not braking, and is easy to hear at slow speeds, especial when running down the alley behind my house with the noise bouncing off the fences. This noise did not stop when I replaced the pads. (next question) It is rhythmic, and speeds up or decreases with the bike speed. In my mind, it's a rotor rubbing or a bearing of some sort. It is not a high pitched squeal, more of a rubbing noise, somewhat similar to the braking noise described below.
Question 2: About 1,200 miles ago, I replaced all pads with EBC fully sintered pads, and hand beveled the front and rear edges. Now when I brake, the pads make a whirring, whooshing, or a throaty ssshhhshshshsh noise that was not there with OEM brakes. (Hard to describe.) Again, this also only happens when they are hot, and is consistent, it does not pulse or pull any direction. I assume this is just the sound these pads make, but it's very noticeable, so I wanted to run it past you experts. I used the pink no squeal stuff, and anti-seize, and think I did everything correctly including taking them to a parking lot and hot-bedding them as BajaRon has described.
Any feedback on these two items?
