Two Brothers muffler
NZSpyderRyder
I have a 2013 Spyder ST Limited and have just purchased a Can-Am Spyder ST/RS/RT (2013-2014) Black Series Slip-On Exhaust System - M-5 Carbon Fibre from Two Brothers. Has anyone else fitted one.
What are your thoughts ?
Am I a virgin
I take it from the lack of replies that no ST owners have fitted a Two Brothers muffler to their Spyder.
Well mine arrived today and it looks awesome, it won't get fitted for a week as I've sent the heat shield, mounting bracket and the nuts and bolts away to get them powder coated in matt black, I'm a stickler for detail and the theme on my spyder is black & white.
I'll post some pictures and let you know how it sounds once it is fitted.
I will be installing one on my 2014 RTS this evening and will post some video of it to compare against the stock exhaust without the cat.
Which two brothers muffler did you get?
i wanna get the single titanium one but with so many other things I want for it if I can't get a programmer for my RSS may not do any of it
Dual system
I preferred the dual system but you can't fit it with the factory luggage that comes with the ST Limited, so just went for the slip on single carbon M5 canister.
I've been thinking about getting the stainless connecting pipe that comes with the kit ceramic coated in black, but I've read there may be some heat issues when using ceramic coating and carbon canisters, so I don't think I'll go down that route at the moment.
Would like to know your comparison of how much louder than stock this is at idle, throttle and cruising. :)
Noise level
I'm not really looking for noise level, I purchased the TBR carbon canister more for the looks, I have a "carbon" theme going on and this fitted in well with that.
I removed the stock rear muffler yesterday and boy is it heavy at 10kg/22lb, compared to the TBR at1kg/2lb, 10 times lighter.
I will be fitting a TBR P1X power tip and this lowers the decibel level by around 5db to 7db.
I'll let you know what I think to the noise level once I get it all fitted.
Sweet Exhaust
Two brothers are great,we have the same set,but had to remove when we needed
hard bags.They won't work with them.(web site warns of this).tyring to sell now.
Also these are very loud,We had to purchase 2 power tip sound surpressors,
dropped sound about 8db,made a difference.(p1X) anyway good luck ,enjoy
i have the pitbul two brothers carbon version. i removed the OEM tip that came on the newer ones. like the sound without the tip. you can add an even quieter tip. it causes a super super very slight drop in hp over no tip
the true sound comes out after about 3 or 4k miles. you need to use it a while for the muffler packing to settle and you can hear what it will sound like. out of the box its quiet.
TBR carbon canister
Finally got my TBR carbon canister fitted, I've had all the stainless steel parts painted black to, after all it is called the "Black Series"
Nicely done..!!
looks awesome. You know how it sounds but fir those that don't check you tube. They seem to have all the type with audio for an approximation...:thumbup:
