Two brothers exhaust + Can Am saddle bags = does it fit??
Hey FrankC,
Looks like you could keep a thermos of soup in that right givi bag & keep it toasty all day.
can of soup
Hey FrankC,
I believe its just the angle of the photo its really not that close, I will measure it later if anyone is interested, my wife has about 30,000 miles with no damage
Dual Two Bro's with bags
Here are the pics I said I would send. ( CJ is sending for Me)
First pic shows the bottom of the exhaust is five inchs off the ground, second pic is the side view of it mounted. Third pic shows you the clearence from the muffler to the bottom of the bag. Forth pic shows I have about an 1" clearence. The fifth pic shows bracket that mounts the muffler to the bike. I used a little piece of metal and drill the wholes. The top bolt has a 1" spacer and the bottom has 1/4". you need to use these to keep the bolts from hitting the tire. Using the bolt that comes with it and match it with another bolt so you have two, then put your spacer on the bolts and screw them in. Make sure the muffler clamp is good and tight and its not leaking fumes.
Thanks so much for the pictures and info. Great explanation. I've been hooked on the Dual pipes sound but have been wrestling with what to do about the bags. Think you helped me make up my mind.
However, I found an old sound clip on Youtube from Lamonster comparing a Venom pipe and another (can't recall brand name). Both of them sounded really deep and rumbly.
Yet again Spyderlover's come through!
