twisties
major911
I would like to know if anyone has had the spyder out on some serious twisties. I rode Ceasars Head last year in SC and the switchbacks were so tight that my 2 wheeler was rarely ever upright and I never made it out of 2nd gear. I'm just curious with the turning radius of the spyder, how well it would handle such tight turns and if any one has experienced such a ride on a spyder?
Awesome video Lamonte. Looks like you really had to slow down to negotiate some of those curves. Well done though, I salute you.
Thanks
Thanks
That was my first run, I've been up there several times on the Spyder now and the Spyder will do all the braking for you if you want it to. Right now I have my front shocks cranked all the way up and I can go through the turns faster if I'm smooth about it. It is a workout though. ;D :spyder:
:congrats: on the video like you say the more you ride the more you learn and the smoother it gets :bigthumbsup: :bigthumbsup: Im still learning on how to ride the curves, :2excited: :hot: :hot: :a18: loving everyminute of it.
It's funny how my zero turn mower is so much like the Spyder. When I first got that mower I thought once again I made a big mistake. I was all over the place and I couldn't mow a strait row to save my life. I was out of control most of the time. I just about gave up on the thing but I kept thinking that the pros use that mower so it must just be me. ::)
Well sure enough much like the Spyder I found that I was fighting the thing instead of letting it take control. I have a much lighter touch on it now and the thing is a real pleasure to mow with. Much like the Spyder, it just took some seat time to understand the machine. :doorag:
aubierules said:
sweet video....how high was the pucker factor?? ;D especially when no cars forever, then boom, cars
It was real windy that day and pretty cold so I wasn't pushing it has hard as I do now. If you ride the Dragon very often you know that there can be a surprise on every corner so that wasn't really an issue for me. :doorag:
i would have had to dig the seat cover out of :edit:
i live in mobile al, and if the elevation changes 10 feet, thats a major hill! ;D
Great video!
How fast were you going and how much of the eleven miles did you cover?
Is the remainder just like the part you covered?
Were you braking on the curves, or did you do it with down shifting alone?
I am looking forward to September.
Spyderperson1026 said:
Great video!
I think from the lookout to the store is about 9 miles if I remember right and I don't remember how fast but I would say on the low side was around 20mph and on the high side was around 55mph.
Yes the whole road is pretty much like that. On the other side of the store is 28 and that's a much better road.
Not too much braking, the Spyder was doing a lot of braking for me. ;D :spyder:
Lamonster - you mention a couple of times " the Spyder will do all the braking for you if you want it to."
Do you mean that in the tight curves the VSS kicked in for you? Or are you just talking about downshifting?
No it will shut the motor down and the next thing it will do is hit the brakes for you. It will about put you through the windshield if you're not holding on good. :spyder:
Wow---- Maybe my reactions are just faster than the computer on the Spyder...... ;D
So do you have to have a wheel come off the ground for that to happen?
Sometimes but not most of the time. The Spyder will pulse the brake as you go into the turn and pretty much shut it down till it feels it's safe to let it go. It's a pain in the butt but I can see why they do it like that. If you driffed into and out of the turn and you let up it would pitch you off the Spyder like a lawn dart. ;D
Great! Thanks Lamont, for the video. I've been wondering how the Spyder would do on a road like that. We have a lot of those out here in CA. I noticed the two wheeler passed you, but he wasn't pulling away very fast, so you were close to his speed. You caught up to the car, so you were a little faster than him.
On my Yamaha conversion trikes, with a narrower front track, I usually lean forward and into the turns with my upper body. Especially since I'm the stability control system!
I pick up my Spyder today and a Kendon folding utility trailer to bring it home on (easier than getting someone to drop me off at the dealer). I needed the trailer anyway for my other toys.
I could have had the Spyder several days ago but I had to wait for a third loading ramp from Kendon. They only come with two; imagine that!
Now I'll have three trikes in my stable - all with two wheels in front!
Frank
Hey Lamont ... You've got me confused!? On the other board, I started talking about the need for a front hand brake to use when riding hard in the twisties. A member of both boards posted the above information in response to a post I made about hitting the curves hard on the Spyder. He made the statement that a person doesn't have to worry about taking a curve too fast on the Spyder because it will automatically prevent you from doing so. I assumed he was talking about when one of the wheels comes up off the road. I don't quite understand what you are talking about?
I can go into a curve as fast and hard as I want to as long as I lean into the curve, get my body off of the seat, lean forward and keep the throttle on! I've never had the VSS kick in UNTIL one of the wheels start to come up. Then and only then has the Spyder reacted by retarding the engine. I have no problem getting a wheel up if I don't alter my position to compensate for the centrifigual force.
Exactly what are your referring to when you say; The Spyder will pulse the brake as you go into the turn and pretty much shut it down till it feels it's safe to let it go. Once again, I've never had the Spyder "pulse the brake" as I went into a turn - - unless - - I go into the curve too fast and one of the wheels start to lift up?!
I mean what I said, it will pulse the brake as I go into the turn. Most of the time the wheel is not lifting when this happens. I have followed Ron through the twisties and his won't do it as much as mine I think because he's lighter than I am. After watching him going through the same turn at about the same speed I got to think it was the extra 30 lbs I'm carrying that makes the differance. That's why I have my shocks cranked all the way up now and that seems to help a bunch along with just trying to go through the turn smoother.
I have no idea how hard you ride but when you make it out this way I'll show you what I'm talking about. :doorag:
Like I said hevn.... I was just telling you what he was saying.
I have not personally had this happen.... I can barely get the VSS to get in with a wheel up.
I think we just might have varying opinions about what 'fast and hard' is....... ;D
My guess is that Lamonster is pushing it much harder than either you or I have or would.
I rode dirt bikes for years and that is my main riding background - so my perspective might be different than yours :doorag:
