turn Signal qusetion
james199
After buying my RT tuesday my lovely wife fell in love with how it rides and she traded her HD ( hardly dependable ) for a 2013 STS . Now my question is does the turn signals have auto cancelation ?
They do on my RT. I can only assume they do on the STS as well :dontknow:
Pam
Yup....
they all do but only on full turns. Slight turn or lane change you have to cancel. Some take a bit longer than others and there were some that had the switch stick. Yours should be fine being newer...:thumbup:
My turn signals will also automatically cancel after 30 seconds if the Spyder is moving.
Is that all the longer it takes? I've been behind a few Spyders and it felt like 30 minutes. :banghead: Whenever I'm behind someone that leaves their turn signals on I usually try to sell them the mirror turn signal lights from TricLED.
On the 2013 ST, they are self-cancelling. I had a sticky issue with my right turn signal, and my mechanic took care of that earlier today;). Just had to clean it. To cancel manually, you push the switch in, like you are pushing a button.
Thank you I thought they would cut off but they're not and it doesn't matter if you turn 90 degrees or not they just stay on so I'll run it in next week for them to fix it as the warranty should cover it
