Tunes for the F3S
It certainly was a fun job.
In the end we put the amp on top (under the windscreen) so we can see at a glance if it's on or off, and whether it's hot. We hooked into the gps plug so it can only be on when the key is on, and put a relay in the Frunk. Nb when I say we, I mean my husband lol. We shall see how this setup goes.
All good except volume has been erratic and frustrating. We had trouble with the speaker connections and, as it doesn't crackle as I insert the 3.5 jack any more, suspect loose connection. Luckily for me Jeff has a bit of time off work before we head from Melb to Adelaide for a spyder muster, so fingers crossed its an easy fix.
When it works, it's brilliant!
I am frustrated - speaker connections all ok. Now suspect faulty amp. Boss Audio have not responded for a week. Not happy. Local supplier has no phone number - there are no stores which stock this or similar systems, hence no help. If the supplier fails to answer my email, we shall pull the amp apart and check all connections. When it worked properly, very happy. However this intermittent fault seems now permanent and it is not fit for purpose. Wish us luck.
