Trying to adapt a Spyder to custom 3-wheeler - any help appreciated?
HDMagnum
So I've had this Tri-Magnum for about 25yrs, was in storage for the last 20 yrs. After purchasing it I installed an '86 sportster as the power plant. 2010-2016 I owned a 2010 Spyder RS, just recently semi-retired and now I want to put an Electric shift Spyder in the Tri-Magnum for the fat tire, hp, water cooled and mechanical reverse. 16yrs of thinking and planning. Basically the donor bike is only used from the fork neck back, so if I utilize a Spyder can I take the front wheel sensors and splice them into the rear wheel sensor ( so to fool the computer that all wheels are spinning all together)? And if I extend the wire harness as needed (moving gauge cluster, handle bar controls, etc) will it throw codes in the computer as it adds a slight more resistance in the readings to the control boxes, etc.? Any help is appreciated.
Very interesting, please keep us posted how you make out!!! It's always fun to think out of the box now and then!! Good Luck
