Trouble with the Spyder
Warlock
Was leaking oil on the left hand side. Traced it to the output shaft seal leaking. Pulled the sprocket and shaft has slack in it. Can move it up and down. Looks like the bearing is bad. Anyone here had the same problem and what it cost to repair.
Thanks, David
Better check your sprocket fit on the shaft, too. Killing the output shaft bearing is usually the last piece of the puzzle caused by excessive belt tension. First the sprocket wallows out, then the shaft slines are damaged, and finally the output shaft bearing fails. They can fail independently, but it sure would pay to check the other components.
...and be sure to have the belt properly tensioned after the repairs.
On my GS 08, Sprocket [front] and shaft, Over 18 hundred dollars!
I could have lived with the 18 hundred, But over 45 days [working days] in the shop, and then it never ran right again after that. :mad:
I had checked the belt, after reading here, when I bought it used. It was too tight and I had backed off it. It was reading around 200 on the kript (sp) gauge. I guess damage already done. Only have put around 4000 miles since buying it. Sprocket and shaft looks good. Thanks for the reply.
David
To get to the main shaft, they need to tear down the engine. Sorry.
