TRIAXIS AND GPS
wmh9680
Hi everyone, it's getting chilly here is Chicagoland.
If I put on the Triaxis handlebars and I have the Zumo 660 GPS can the GPS just be mounted on the handlebars left or right side. Thanks, Mike
I have the Triaxis on my 2016 RTL. It came with the 660 but the bracket for it is different for the triaxis bars. When the dealer installed the new bracket it was for the 590. Apparently CanAm had already started the switch to the 590's.
Sent from my SAMSUNG-SM-G935A using Tapatalk
I dont think you will have enough slack in the cable to mount it on the left or right side unless you get creative with your routing. I just went through this same thing when I installed min a few weeks back. I went with the center mount on a RAM ball.
Mike,
There is a special mount for the 660 garmin for the tri axis bars,it is pricey.I don't have the part # but maybe someone on here does so you can get the right one.I found mine on ebay that a dealer had laying around and got it at a reasonable price.
Although I don't know about the cable length for the 660 mount because my mount is for a 590, if they are the same length you could mount the GPS on the right bar with some type of mount other than the Tri-Axis center mount but mounting on the left bar is unknown because I don't know how much cable, i.e., slack, remains under the Tupperware.
