Transmission slipping RS SE5
boomboom1
I have been experiencing slipping of the transmission when changing gears. It seems to hesitate between gear shifts. My Spyder dealer is not yet sure what is causing the problem but thinks it may be an oil leak in the oil pump. Has anyone else had this probelm? Any advice?
Thanks,
Boomboom:yikes:
Do you roll off your throttle then shift? Try to keep rpm then shift. This is how I do it with my 2012 RT SE5 and no problem.
Oil level is critical to smooth shifting on the SE models.
First, Oil Level is at "Full" mark when at operating temp.
Second, Try shifting @ no less than 4k RPM
-Mike
<Sent from my iPhone using Tapatalk>
I've found that on my 08 SE5 when it is getting close to an oil change it will act up alittle initially was thinkinking shift selenoid or relay but nope tuns out it is just tempramental.
