I have a older backwoods bungalow trailer I've been working on. After reading the forum on adapter plugs and such, I ordered the digikay plug and pins.
After getting the plug it did not come with a back cover so I went to Lowes and gor a electrical 1" conduit cap. I drilled a hole to pass the wires through. When i confirm the pins are correct and seated to pass voltage I will either use silicone or epoxy to fill the cap and water proof the connection.
The only big issue was getting the pins far enough in the plug to make a good connection.
All in all it will be worth the effort.
I did have the dealer install the hitch and BRP connector on the bike.
Gary
Gary
