BJT YOUR THE MAN!!!!!
I got a brochure. It is $4000 plus more for two tone paint etc.
Nice, but too pricey.
I just bought a 6.5x12' all aluminum trailer with ramps. It's so light I can unhitch it and PICK IT UP by hand to move it next to the garage.
If you are looking for something not as fancy (and expensive) look for an aluminum trailer.
http://www.redhottrailers.com/aluminum.htm
They have a new aluminum trailer to fit the Spyder for less than $2K and it weighs around 450lbs. Of course adding the front rock guard and wheel chocks etc. adds $.
I don't know what the rated trailer rate is for a PT, but for my wife's HHR it is 1,000 pounds. Take a Spyder that is pushing 800 pounds, and that doesn't really enough capacity for a trailer. I would doubt you could get the whole rig to come in much under 1,500 pounds. Be careful, these little cars don't have engines, suspensions, and transmissions made for towing, especially through the mountains. Nothing worse than being broken down on the side of the road with thousands of dollars of motorcycle on an open trailer. Don't ask how I know! When you are stranded with a trailer, you are really starnded.I will soon be in need of a trailer to haul my spyder to Fla.
Looking for safe suggestions for a light and small as possible trailer.
I am using a PT
Size (SMALL) and weight are the TOP priority, I am hoping to keep it in 1/2 of my 2 car garage. I have seen Aluminum trailers, but when you add the wheel wells they come in at about 8' wide. Kinda looking for something smaller.
-Scotty
I certainly wouldn't do it. No frame on a PT, for one thing. You will be pulling with the body panels. I just went to a larger truck to tow my 3,500 GVWR trailer. My old truck had a towing capacity of 4,500 lbs, but the bigger trailer was a strain, and mechanical breakdowns became more frequent. It is considered to be unsafe to tow a trailer whose weight is more than the vehicle towing capacity. I had a bad towing accident that way years ago, so I believe them. It is also illegal in most states to tow a trailer whose GVWR (Gross Vehicle Weight Rating) is more than the tow vehicle's rated capacity. Unlikely to get busted for it, but in an accident, they would surely nail your hide to the wall, and a ticket would be likely. How about adding a Bushtec hitch to the Spyder, and forgetting the Cruiser altogether?The PT GT is also $1000 Lbs. was HOPING those were conservitive towing weights.
Could I get a general consensus here (I have never pulled a trailer with my vehicle) Is this a really bad Idea? Or is 1000 lbs. the limit??
