Towing 2 rt spyders
estephens
I am thinking about getting an enclosed trailer to haul my 2 RT 's, I know the spyders equal in length almost 18 feet front to back, has anyone hauled there spyders this way and what size trailer do you suggest. Thanks for your help.
Trailer
I've got a 7' x 20' enclosed Titan by Stealth. It will haul 2 RT's with hitches. Might change to a 8.5' x 18'. A 16' may even work if you don't mind bouncing the back end of the RT a little to get it in a better position.
If I were to buy another trailer for my RT, it would be 8.5" wide. The 7ft. wide trailer, I have now, does not allow enough room to comfortably get around the front wheel to secure the front end.
I have a Wells Cargo CycleWagon, with interior dimensions of 20' long by 6' high by 79" wide. It was designed to haul 4 dressers. Our two Spyders fit nicely in it. By the way, this 15" tandem axle trailer is very well made. It is intended for daily use and 20 years of service. It weighs 2800 lbs empty with a gross weight of 7000 lbs.
I have an 8.5 by 20 V nose enclosed trailer to haul my RT-S Spyder and an 1800 Goldwing it works great and gives me the walk around room I was looking for. I tried a 7 X 18 and it was a little too snug.
:dg2:
