tork wrench
spyderpoop
to remove the body panels of the spyder it has funky screws are they tork screwdriver tips and what size do ya need to remove them ? will a auto part store sell them ? thanks Rich
Yes you can get the correct screwdriver at most hardware or autoparts store. There is one in your tool kit.
By the way it's Torx.
If you have a RT, there are a couple that never should be removed. They are easy to spot since they don't look like the rest.
You should have a Torx wrench/driver in your toolkit. You can find a wide variety of screwdrivers, wrenches, and interchangeable bits anywhere that sells tools. As was said, do not touch the silver security screws with a stud in the center of the recess. Instructions for removing the body panels are in your Owners Guide.
You should have a Torx wrench/driver in your toolkit. You can find a wide variety of screwdrivers, wrenches, and interchangeable bits anywhere that sells tools. As was said, do not touch the silcer security screws with a stud in the center of the recess. Instructions for removing the body panels are in your Owners Guide.
Where on the RT would I find one of these? I haven't run across one yet, but I've only had the panels off for oil changes / maintenance so far...
I think he was going for silver security screws. They are located on the middle panels just below there your knees would be.
LOL! Those must be the ones!! Before I ever removed a panel, I watched Lamont's video, so I never even paid attention to those being security screws! I just never paid them any mind at all...
Thanks!
As for the sizes of the bits... most panels come off with a #27 torx, but I found a few smaller ones that use a #20. I also found that the tool provided in the kit seems to have one size that doesn't fit anything (at least that I've found yet)
