Topping off air bag
I have a 2012 RT A&C and I have to top it off at least once a week. It has been repaired for a leak but it still loses several lbs/week. Not really a big deal if you have a portable air pump. I can tell when it needs air because the rear sags a good bit and the suspension is low and bouncy.
No need to
Fro your profile you state that you have a 2016 RT Limited. That being the case and the system was calibrated correctly it will automatically keep the ride height that you selected on the screen when you push the air shock switch on the switch panel. See the details on how to adjust it in your owners manual. Only the base model RT owners have to manually have to air up the system.
'13 RTL Checked my pressure the first time, it was at 20lbs, upped it to 50lbs and it's still that every time I check it.
