Top Case Removal
stebrock
Just traded my 2016 triple black F3 L on a 2018 Steel Black F3 L.
My plan was to remove the top case when not needed. I've looked in the accessories catalog and don't see the necessary "cover" to install with top case removed.
Anyone know if this is available?
Where to obtain?
How much $ ?
Thanks, Rick
Here you are. you are in a better spot than me as I have a pearl white F3L and could only find a black rear fairing so I purchased it and plasti dipped it with white pearl. Its not a perfect match but it works.
Here's a link for the steal black fairing. item #20 part # 708001786
https://www.cheapcycleparts.com/oem...3666/body-and-accessories-cargo-package-t-ltd
I actually will sell you mine as I never use it I will take the plasti dip off of course. it is very slightly used I will sell it to you for 120 shipped if you want to save a little cash
There’s no additional hardware to install it snaps into place and the rear seat goes over it to snug it up.
Thanks for the info but I found a black one.
My fiancé is ordering a pearl white limited from Imotorsports. If she decides to remove the top case I'll get in touch with you.
What needs to be done about the antenna when doing this?
Good question. Hadn't thought about that.
I have noticed that my 2018 radio reception is a lot better than on the 2016.
I mostly plan on using my SiriusXM phone app bluetoothed to the radio,
