Top Cargo Shelf & Trunk Liner
upsdoctor
I ordered and received the Top Rear Cargo Shelf p/n 219400232 and the Top Case Molded Inside Liner p/n 219400246 from the BRP online store. It appears that I cannot install the shelf with the liner installed. Has anyone installed both of the kits together? :helpsmilie:
The shelf is supported by a strap attached to the existing screws on either side of the rear compartment. You just need to cut a small hole or slit in the linner at these two locations, bolt your strap brackets in place and you're good to go.
