If they are OEM tires, they are directional.Have any of you people crossed your front tires ?? I mean just switch them wheels and all from one side to the other. The tires will then be running backward in relation to the way they were running.
If you rotate your front tires, you have to dismount and remount them so they are going the proper direction. Popular wisdom on this forum says don't bother rotating them. I have nearly 14,000 on mine, and they still have great tread depth measured evenly across the surface. I decided to obey the common wisdom and have refrained from rotating mine.
There're a couple of threads on this topic.
Pam
....This begs the question ?????.... WHY....if you answer this .....Maybe we can tell you more info......Mike :thumbup:Have any of you people crossed your front tires ?? I mean just switch them wheels and all from one side to the other. The tires will then be running backward in relation to the way they were running.
Well the Owners Manual does say to rotate them (on a 2013 RTL) when the tread depth reaches 4mm (5/32") to maximize tire life, but I have seen no uneven wear on mine. I think that proper inflation & the Laser alignment has helped.
From what I have read the directional restriction is based solely on the the tread design. Structurally there is no significant impact in reversing the rotation. Tires with a bi-directional tread pattern can be run either direction.I am pretty sue that ALL MC tires are directional. Running them the wrong way is inviting tire failure, or worse. Some car tires are directional as well, like my snow tires.
:lecturef_smilie:......If a tire has " arrows " on it ......it better be rolling in that direction........They aren't put there as a decoration:shocked:......Mike :thumbup:From what I have read the directional restriction is based solely on the the tread design. Structurally there is no significant impact in reversing the rotation. Tires with a bi-directional tread pattern can be run either direction.
That's because of the tread pattern, which I believe matters mostly on wet roads only, not dry roads. Yes, it is best to run them in the arrow direction, but the world won't come to an end if they run the other way. In fact, when I was first looking for a used Spyder over 2 years ago my brother checked one out for me in Houston. It had several thousand miles on it. He pointed out to the owner that the front tires were mounted backwards. Didn't hurt the Spyder any!:lecturef_smilie:......If a tire has " arrows " on it ......it better be rolling in that direction........They aren't put there as a decoration:shocked:......Mike :thumbup:
[TABLE="width: 820"]
[TR]
[TD="width: 400"]Directional Tires will have an arrow on the sidewall. If it doesn't have an arrow, it's non-directional! and it doesn't matter which way it rotates.
Directional tires are primarily about wet traction - although snow traction is sometimes the intent in the design. As a general rule, directional tires will have an "arrowhead-like" tread pattern - it seems to point in the direction of travel. If you mount a directional tire backwards - so that it is rotating the wrong direction - the only problem caused is wet (or snow) traction. It does not affect wear, pull, dry traction, ride, or any other characteristics. If you have one of those problems, then the problem has nothing to do with the direction of rotation of the tires.
If you are mounting directional tires on rims, you want 2 tires pointing one direction, and 2 tires pointing the other direction.
Directional tires can only use a front to back rotation pattern - no switching the tire to the other side.
CAUTION: Some rims are also directional, so a little care before doing any work will pay many benefits.[/TD]
[TD="width: 20"][/TD]
[TD]
[/TD]![]()
[/TR]
[/TABLE]
[TR]
[TD][/TD]![]()
[TD="width: 400"] Sometimes it appears that a tire has a direction to it, but it doesn't have an arrow - like the tire to the left.
While this tire seems to be directional, it doesn't matter which direction it travels - and I'll explain that in a minute.
Let me say it again:
If it doesn't have an arrow, it is not directional![/TD]
[/TR]
[/TABLE]
