I think you'd be hard pressed to tell if there was any real difference in the
ride between a T rated tire and a V rated tire, even if they were otherwise identical (& few are!) Our Spyders just aren't set up with that type or degree of 'tight suspension & frame rigidity' in them!! There's just waaay too much bush & frame flex, and the OE shocks & coils are pretty forgiving & cushy too, so any difference between the two different tire ratings will just get lost in amongst all the other little bits of flex & cushiness & give!
pps:
But tire wear & life, you might possibly notice a
little difference between the two there. Possibly, you might even notice some difference the various compound's heat tolerance brings to how 'grippy' the tire feels in its handling, so you
might be able to tell there's a difference in handling performance at the extremities of the Spyder's capability,
IF you ever get your Spyder out there!! But really, both of those tires are going to be so much
MORE tire than what our Spyders actually need that you'll very likely never reach the tires extremities! And if you've come straight off the Kendas, you'll just be so happy about how much better everything feels that any/everything else will just blur into the background noise until it comes around to tire replacement again! And
that's a little difficult to predict, not only because of the different ryding styles, conditions, & loads etc that each ryder might have, but also because most tire manufacturers have their own little secrets & tricks that they believe make the critical difference in their tires vs anyone elses & between their tires various ratings!! Altho they do test tires to destruction to arrive at those ratings, so if you plan on ryding at sustained speeds in excess of 149mph........
H0gr1der, YOU
might get a little better tire life out of the V rated tire than SpyderAnn would if she ran one, but I expect the T rated tires she runs will be much better suited to her ryding needs than a V rated tire would be anyway, simply because of the number of long miles with relatively high loads while travelling at less than the V fast speeds that she tends to ryde & that I doubt you do or will do frequently, so it's not really a fair comparison. Maybe you'd get better tire life from a T rated tire as well, but would that come at the loss of some degree of traction or wet road grip over what you'll get with the V rated tire?! I don't really know, & I think you'd be hard pressed to tell too, at least without either/both of us spending some quality time on a skid pan with some pretty expensive testing gear. Either way, I'm firmly of the opinion that either rated version of these tires will suit your ryding needs/wants significantly better than the OE Spec Kendas do, so I reckon you are already onto a winner there..... the little differences that might be gained by running a T rated tire versus a V rated tire or vice versa are really going to be minor when you stack them up against the fairly significant benefits you've already felt between running the Kendas & running a 'real' car tire at or around the right pressure for the load! And then there's the expected tire wear & life benefits between a Kenda tire & any other car tire too. So you're a winner already, it probably doesn't pay to get
too stressed over the minutiae.... :lecturef_smilie: Well, that is unless someone wants to pay me to do that testing, of course?? I've got some skid pan time due!?! Anyone?!?
