viperryder
Just had a problem with a tire sealant supplied by one of the sponsors. Purchased and put in all the tires on my Spyder, about three months ago. Before going to Spyderquest, I did a check on all the moving parts on the Spyder and found that the right side tire was low. Put air into the tire and checked it the next day. Went from 18 PSI down to 13 PSI. Filled it again and found the pressure went down to 17 PSI. Went to Spyderquest with low pressure. Returning home and checked it again, pressure was down to 12 PSI. Took it to where I had tires mounted, and he was not able to find leak. Took tire to a regular tire shop. They had it for a day and a half. Finally called, they informed me of the gunk inside the tire. They mentioned that the gunk was filling all the small cracks and that made it very hard to find the leak. They even mentioned that the material was starting to get hard. They said that the way the tire was, with the sealant in it, they would not be able to find the leak or even fix it once they found it. End of story, I ended up purchasing two new tires, as they said could not fix. Just letting all Spyderlovers know my problems.
