I wonder what pressure I should use when I switch to car temporary spare tires when I need new front tires? They are slightly narrower than the current front tires.
Generally, those Temporary/Space Saver Spares are 'smaller volume' tires that need significantly higher air pressure in them to carry the same load as the tire they are replacing, so you might want to check the pressure/load info for the particular tire with its manufacturer, once you know the load your Ryker will be putting on it! Also, most car temporary spare tires will have a lower speed rating than the OE Spec tires on your Ryker, so you should check the legalities of running them wherever you are. :dontknow:
Running a lower speed (or load) rated tire than the OE Spec tire is definitely NOT LEGAL at all here in Australia! :lecturef_smilie:
Even cars with Space Saver Temporary spares note the speed limited rating on their tire placards, have stickers & directions all over the place reminding people not to drive the car too far or too fast once the spare is fitted, & the space saver tires are fitted onto different (brightly) coloured (space saver) rims so that anyone (ie, Police...) can tell at a glance that the vehicle is not meant to be being driven at speeds higher than 80 kph! (50mph-ish) There are also often (technically) time & 'distance in use' limits on those tires - they just aren't intended or designed to be used as a 'full-time/service tire' at all! I wouldn't recommend running them on anything except as the temporary spare they were designed to be! :shocked:
Why don't you fit a similar sized 'proper' car tire? There are slightly different sizes available that meet or exceed the OE Spec Load & Speed ratings, and some even get very close to the same rolling diameter as the Kendas so as to keep the Nanny happy! Altho she really isn't all that likely to be upset by anything within about a +/- 10-15mm rolling diameter variance. There's really no need to fit a Temporary Spare, which is very likely an even LESS suitable tire than the OE spec Kenda - while it might be quite hard to believe that's even possible, running a Temporary Spare as a 'Full-time/service tire' will be doing just that! :gaah:
But it is your Ryker & your life.... and maybe the life of the person/s you could hit when your 'temporary spare' fails due to its misuse.... :dontknow:
