Evaluating my Tire inflators, gauges, and FOBO2
UtahPete
Well-known member
At this post in thread 'Modifying these Tire inflators and different air chucks to see what works best for me...' https://www.spyderlovers.com/thread...ee-what-works-best-for-me.168056/post-1770514, I said I was going to evaluate 4 battery-powered inflators and 12 different tire gauges to identify those I could rely on for accurate, consistent results.
My two Ryobi 18v inflators tested well (at both 20psi and 30 psi), both coming in at about 1psi higher than actual on the built-in digital gauge, which also lets me dial in a preset pressure. The other two Ryobi inflator gauges were way off, reading 5-8 psi lower than actual, so they are still okay to use in conjunction with a separate gauge, but not standalone like the first two.
Of the gauges, the two analog JACO gauges were both spot on, as were the two small digital gauges (Accutire and Roadgear). The two ARB analog gauges, the two Most analog gauges and the one Motorluxe analog gauge (all round dial) were also very accurate, coming within 1psi of actual.
I inflated all 3 tires to 21psi via the Ryobi 18v digital (which is 20psi actual) and reinstalled my FOBO sensors. Voila, they all now read 18psi, which is great because they are known to read 2psi low (Google it, or read comments elsewhere on SL).
The source of air pressure I used for testing was a 20" wheel and snow tire that came off my previous truck. It has twice the volume of a Spyder tire and is thus less susceptible to pressure drop as I applied and removed one pressure gauge after another (I also reinflated every so often, plus ran the test in reverse order, so it was pretty stable).
Using that tire also enabled me to place it at a convenient height and in good light, which wouldn't have been possible with one of my installed Spyder tires.
Yes, I really do think about things like this at night when I should be sleeping. As I admitted in a different thread, I don't get invited to parties much!
