Tire Help in Florida
rsnider1961
My 2020 RT Limited is now close to 11K miles and I am needing a new rear tire. I just left Sky Powersports in Lakeland to see about installing the Vredestein Quatrac 5 on the ride and they refused due to "liability." I am now trying to locate a shop (hopefully) in Central Florida that would be willing to install the tires. I am willing to purchase through the shop or purchase and bring in for installation. Does anyone in the group have a suggestion on where to find a shop that might be willing to help?
Thanks for your input in advance...
Try going to a motorcycle shop to have the tire mounted if the wheel is already off the bike. That's what I had done when I replaced it with a Kumho tire on the rear. If the wheel is still on the bike I can't help you there as I'm on the opposite coast of Florida from you.
I live in Vermont so I can't help with that question .... however if you can remove the front wheels , buy the tires and bring with yours to any shop that does tire changes .... they can probably balance them also ..... good luck ... Mike :thumbup:
I pull the wheels off and take them to a local tire shop. They will mount the tires on the wheels, but won't take the wheels off and put them on. Removing the wheels is not a big job.
Action Can Am in Bradenton said they will mount my non OEM tires on my 2020. They never use to. I know I told them I did not like having to travel an extra hour to Barney's in Tampa area to get my General mounted 2 years ago.
You can also call Seminole Power Sports. I believe they will do it. Sanford, and Eustis. :thumbup: Tom :spyder:
After calling around I found Seminole Powersports to have the best deal. They would only sell me the Kendra, however, they are willing to install the General Altimax RT43 tires if I purchase and bring to them. There price is $205 to remove wheels from the bike, mount the new tires and reinstall on the bike. I have ordered the tires and will hopefully take care of this next week.
I have a 2020 RTL that I purchased last August and am getting it ready for a fun summer. I was on a ride through Georgia a couple weekends back and got into some rain. As I was going, it hit a puddle and hydroplaned a bit, however, I was able to keep control. During the event my Pedal Commander started acting up. As I would give the bike throttle, there was about a 2-3 second delay and then when I would let off the throttle there was a 2-3 second delay. Also, the throttle response was very iffy in how much power would be applied and then how slow if would ease off. My wife and I found a hotel in Waycross and I took the Pedal Commander off, made sure it was dried out overnight, reinstalled the next morning and everything has been good since.
With all of that said, I realized that I needed to have better tread on the rear tire as I now have approximately 11K miles on the factory tire. The tires cost me $276 and the mounting will add another $205 - for the safety factor (and hopefully better ride quality) I believe this is a wise decision. As I spoke with the sales team at the dealerships they warned me that I was making a bad decision going with a car tire and said I would have sidewall issue, however, I have not heard of that issue on this forum from anyone that has went that direction.
Thanks all for your help.
The main thing that I think you need to do is make sure of the air pressure they put in the tires. There's lots of threads on here about that.
Try RideNow Powersports in Ocala
