I just removed my rear tire, took everything apart on the wheel and got a new tire installed and balanced on the wheel. I followed Lamonster's video for getting the tire off. There are a couple of things I noticed and have questions about. My Axle which has a nut on each end is free spinning; so, when I was taking off the nut on the right hand side the whole axle spun and I had a heck of a time getting the nut off. Any suggestions? Also, when I put everything back together, the drive for the belt did not fit flush to the wheel. Does this all get pulled together when you tighten the axle nut? Am having trouble tightening the axle nut because the axle spins even when I hold the nut on the other side. Just think I am doing something wrong. Any help would be appreciated. Thanks
