Tip on installing Belt Idler for the F3T
Buckskin
Just got though installing the Idler pulley on the F3T. Most will likely use Lamont's video to see how to do it the easy way. I found I needed to be able to hold that bolt in the socket while installing in the threaded hole. I use a piece of paper towel to capture the bolt head in the socket while I drop that extension and socket down about 8". Note the picture below.
Buckskin
Works....👍
I magnetize the socket but not everyone can do that. Your solution is quick and simple and all you need is at hand...:thumbup:
Front sprocket cover
I just removed the front sprocket cover (3 Allen head bolts) and you can reach in from the front easily.
Neil
Neil are you saying you didn't remove the side panels at all? Or only what you did to get the wrench in on the bolts?
