OK happy to say..... All parts ordered from Baja Ron to do the job myself.
This is what's on the list:
1) Oil change of course
2) Air filter replace
3) Spark plugs and spark plug wires replaced
4) Rear brake pads
5) Flush the brake fluid and replace. I am a little nervous about this procedure without having BUDs.
I do have a car vacuum bleeder so I think I am just going to go for it fully rather than do the old school pump the brake peddle, open a bleeder tit, etc.
The fluid in the reservoir looks clear and clean but it says to replace the fluid so I am going to do it. Time to study up on what others have done here.
6) Coolant flush and replace.
7) Clean the throttle bodies.
8) Lube front suspension arms. Have to figure out and study the lube tit issues again.
Things I am not going to do:
1) Check the valve adjustment unless I decide to do it when I get there. Pretty sure I am going to skip it.
2) Bearing seals on rear wheel. Just had the wheel off to replace the tire. Seals looked fantastic!
Over and above:
Going to do a canisterectomy! Had I taken it to the dealer for this 14K service I would have that replaced under warranty. But what's the sense?
It would just get fouled again later and my Jan 2016 no more warranty for me. Thus it's time to just resolve the issue and gas stink.
I will probably be doing this about mid April based on current mileage. I will video what I can but for sure just enough to document what I have done in case I do need warranty work before Jan 2016.
Thank again all for the advise. It helped sway me one direction which as some said, I knew the answer all along. Just needed a push in the right direction
Bob
