throttle question
muonwhiz
When driving the paddle shifter, are you rotating the throttle closed before shifting and then rolling on again? I find I have this habit from my other days riding 2 wheeled machines with clutches, but don't know if it makes a difference here. ????
NO - The SE5 is designed to be held wide open when shifting
:2thumbs: Keep your RPMs up around 5ooo and shift away, holding the throttle steady and it should be smooth as silk :2thumbs:
I used to do that too, but found much smoother to keep throttle steady and just tap paddle. Big difference;)
Let the SE5 do the work
Like the others above have already said...keep your throttle position steady...it will blip the RPMs for you when shifting.
Since it's a throttle by wire setup, it automatically drops the revs for the shifting. You just hold it steady and let the computers do their dance! :ohyea:
