throttle body
clayw
I thank can am has a problem with the throttle body I was on a 6000 mi. trip my throttle body quit and I brought spyder home in a u hall truck. It is at the dealers now it will cost me $1300.00 th have a new one installed I only have 22000 mi. on my 2010 RT. I am thinking can am is junk and that is the niceded thing I can say:banghead:
Some 2010 and 2011's were shipped with throttle body firmware that was overactive and caused problems. There was a recall and most throttle bodies were replaced. Check with the dealer to make certain your throttle body was one of those affected.
My 2011 RT-S throttle body failed and was replaced free by the dealer. As said, have the dealer call BRP and see if it can be replaced at no charge to you. After replacement, my 2011 ran like a hose. Dealer should go to bat for you!!
:spyder2:
If you read the bulletin I posted, it tells the dealer to file a case for a "good will" warranty replacement.
Hopefully your dealer will do that!
Bob
