I picked up a new engine for the F3 and while swapping over the transmission cover, the valve cover and the oil pump cover, I broke one of the bolts off in the engine. RT engine to an F3 engine. The old engine (F3) has the powder coated covers, whereas the new (used) RT engine did not have the powder coated covers because it is covered by the plastics. I was using a torque wrench but not a good one. (Harbor Freight).
I searched the forum and sure enough, I read of SEVERAL ways to remove the bolt and the first way that I tried, worked.
Sprayed it with some PB Blaster to get everything loose. I used my Dremel tool and carved a grove into the bolt. I was able to BARELY get the grove made, making absolutely sure I did not hit the engine. Once the groove was made, got a screwdriver and out she came.
Thank you again!!
Thank you again!!
