Decided to take an evening ride today as the humidity had dropped and it felt rather nice. I got about 15 miles from the house and came to a stop at a traffic lite. Thought I caught a slight whiff of engine coolant, but didn't think much of it as I had always detected such an odor from other nearby vehicles.
Glanced down at my gauge cluster and observed the temperature bars showing 8 instead of the normal 4, then had an orange engine symbol start to flash. Not good.
I pulled into the nearby gas station and shut everything down. Waited about 5 minutes and re-started the engine and everything looked normal again. headed back home anyway. As long as I kept moving, the temperature bars showed the normal 4.
Half mile from the house, another traffic lite and the temperature bars started climbing again. This time, I got a "Limp Home" on the cluster, which disappeared as soon as the bike started moving, and the temp bars went back down.
Finally got home and pulled in the garage and let it idle for a few minutes and watched the bars start to rise again. Shut it down.
I pulled the cover off the coolant overflow tank and could not see any coolant thru the side indicator marks. Popped the cap slowly, which only slightly hissed and literally could see nothing inside the tank with a flashlite. Started adding some coolant slowly and after about a pint, could barely see any coolant at the bottom of the tank. Also, about then, there appeared a very small spot of coolant under the bike.
A quick check underneath the bike showed coolant drips collecting along the tubular frame piece and the plastic under panel.
Guess I'll be jacking it up and pulling panels tomorrow to see what's going on inside. Praying it is something minor that I can correct and not have to make a dreaded dealer visit........
ray:
