glynnk
RT-S PE#0134
Took the Spyder in for the update #2 this past Saturday with an additional problem--the handle bar had developed some "play" in it. You could move the handle bar up and down on either side--not a lot, but it was noticeable. The only other time this has occurred was on the day I bought it new with a dealer installed 1" riser. The "play" then was a lot more pronounced. It was determined that the dealer install tightened the shaft nut too tight and a bolt was snapped off making the handle bar very loose. This episode is not nearly that bad, but it's a concern that something wasn't done right on the riser install. Has anybody else had this kind of issue come up?
Glynnk
Glynnk
