Symptoms of bushings on a-arms going bad
aka1004
Will it be undesired side to side wobble/slide or bouncy or rough ride?
While I was taking a high speed curve, spyder felt like it was going under.
Could a old rear shock cause this? I have new rt shocks up front but original rear.
Thank you in advance.
I checked it that day. 28 up front and 30 I'm rear with falken car tires.
It also feels like spyder bounces side to side just slightly more than before at freeway speed.
Just my opinion but 28 for the front seems high, That might give you a little bounce.
I used to run 18/19 front, [GS 08]
Bounce was not a good choice of words.
It's more of side to side slide at high speed only. Just wiggles around in the lane and seems like I have work a little more to keep it straight.
Remember I have falken 512 that requires a lot more psi than kenda.
I've been running 26-28 psi all this time but this slight slide side to side just started.
Could be both ball joints and bushings. That is what I found. Fixed the ball joint and now I've got to replace the bushings.
Any special tools needed for the job?
I wonder if I can do this myself...
What am I looking for? Loose bolt? Something cracked?
I am not close to being a mechanic but pretty familiar with spyder but not with a-arm part...
It looks like $500 just for parts if I replace all ball joints, cirlok, bushing and cushions, parts numbered 6,7,8,9 on microfiche.
I guess bushing and cushions will need to be pulled out to check but what would a bad bushing would look like? Crushed or broken?
Would a bad ball joints have obvious physical flaw?
Thank you much.
Bad parts have play in them when the wheels or a-arms are moved, shaken, or wiggled. All except the shock bushings are usually checked with the machine jacked up, but the wheels still attached to provide a bit more mass when you move things. If you have a shop manual, it will tell you how to check each component...except maybe the shock bushings. To check those have someone bounce the Spyder up and down while looking for play at the bushings...or shake the shock up and down by hand, looking for movement at teh bushing(s).
Thank you.
Unfortunatly I don't have a manual. Can someone please give me short direction how tO check a-arm bushing and ball joint?
Also, type of grease and grease gun I need for a-arm bushing. :)
