thunor
I have a very weird config issue with my iPhone and 20s.
If I use Waze on the iPhone 6 Plus I can get the sound to come through my Spyder speakers. If I have the Audio on iPod then it will cut my music
off on phone calls and they get routed to my 20s. If I have the Audio on FM then I get FM and BT at same time so I turn down the Spyder Audio to
take the call. This seems to be my best setup currently.
If I try to use Sygic on the iPhone with the devices plugged in identically to above(iPhone using iPhone/iPod port) then I get zero audio from Sygic to
either the Spyder speakers or the BT. If I go into the settings in Sygic and tell it to play over the speaker(option in app) then it instantly flips music and
GPS to BT and I get zero audio through the Spyder.
I would like to get the Sygic app to feed through the Spyder speakers but for some reason this app does not play nicely like Waze.
Thoughts?
This is currently with my iPhone stuffed into the trunk plugged into the IPod port(with Lightning to 30pin adapter from Apple).
This is on a 2014 RTS...thanks in advance.
Thoughts?
