eddieshep999
I am thinking of fitting a new Horn to replace the original one
I will use the STEBEL Nautilus Air Horn COMPACT
I was going to wire it direct from the battery via a Relay but as its not
likley to be my last accessory so I have decided to fit a
FZ-1 Fuseblock see link
http://www.fuzeblocks.com/
I need to find out the following :-
Where to take a Switched Power Source from my Spyder RT -S 2010 Model
The installation instructions state -
[FONT=Arial, sans-serif]Connect a 12 to 18 gauge wire (18 gauge is usually[/FONT]
[FONT=Arial, sans-serif]more than sufficient) from the +VT input (J1) to a[/FONT]
[FONT=Arial, sans-serif]switched power source on the vehicle.[/FONT]
[FONT=Arial, sans-serif]A switched power source is a wire that is +12 VDC when the vehicle is on and 0 VDC when the vehicle is off. [/FONT]
[FONT=Arial, sans-serif]Refer to your service manual, local mechanic and/or internet forum* (*This is where your assistance is needed) to find a[/FONT]
[FONT=Arial, sans-serif]suitable switched source for your particular vehicle and[/FONT]
[FONT=Arial, sans-serif]for the best procedure on tapping the wire.[/FONT]
[FONT=Arial, sans-serif]The switched source is used to energize the FZ-1's relay coil (about[/FONT]
[FONT=Arial, sans-serif]1A) which will cause the relay contacts to close and supply +12VDC from the battery to the switched +12V output bus.[/FONT]
[FONT=Arial, sans-serif]I intend to fit this Fuseblock near to the front of the Spyder to allow [/FONT]
[FONT=Arial, sans-serif]easy access - under one of the front service panels if enough room
[/FONT]
[FONT=Arial, sans-serif]If someone can advise me the best access to get the switch power source from this would be helpful
[/FONT]
[FONT=Arial, sans-serif]Thanks
[/FONT]
[FONT=Arial, sans-serif]Eddie Sheppard
[/FONT]
[FONT=Arial, sans-serif]Reading UK
[/FONT]
[/FONT]
[/FONT]
[/FONT]
[/FONT]
[/FONT]
